ryno1234
- Joined
- Dec 8, 2014
- 139
Just one of my manifolds becomes very hot to the touch. You'll definitely burn yourself if you left your hand there for 1-2 seconds. The other manifold is very warm to the touch, but it doesn't seem like it would burn you. The engine is NOT overheating.
I did find what I believe was an exhaust shutter in the outdrive when I removed the outdrive a month ago - just half of one shutter. I removed it. That said, I'm not sure how an exhaust shutter would affect a manifold being warm vs. hot, so I'm thinking this may not be related.
Any ideas come to mind about what would cause this with one manifold?
The boat seems to run fine and honestly I forgot about this issue and we've taken it out several times since I discovered this originally.
EDIT: What are the concerns of the manifold running hot? What are my risks?
Specs:
1998 Maxum 2400
5.0 Mercruiser Alpha Gen II
Raw water open cooling system.
Engine serial number: 0L027045
Specs:
1998 Maxum 2400
