One Man's Manifolds 5.7 Mer...
After running my boat engine for a bit, which by the way is a 2000 GM MerCruiser 5.7 carbed with thunderbolt ignition, my starboard side manifold is significantly hotter than my port side manifold. I can put my hand on the port side manifold and it's just slightly warm but my starboard manifold I can barely touch...
Temp gauge is reading nothing hot, although I'm not sure where it reads from, she hovers right around 140 degrees. I did notice a bit of a spike in oil pressure when first hitting the water, but that leveled out after a short time as well.
Any thoughts on why one manifold would be scorching hot and one not? and is this a big deal, or am I over thinking it...
Nothing to worry about, one side will always be hotter then the other. Just a fact that water flows the path of least resistance. So long as when you touch it your not burned instantly you should be fine
one manifold usually gets a bit more flow than the other.
your oil pressure will always be higher when you first start the motor (oil is more viscous when its cold)
Ayuh,.... Welcome Aboard,.... 140? ain't Hot for a motor, but it'll burn yer hand quite badly,....
One side always runs hotter than the other, usually starboard, but not always,....
