Texasmark
- Joined
- Dec 20, 2005
- 14,795
I got my linkage parts in yesterday and installed them. Then I went through the linkage setup per the manual and in hindsight it looks like I got it all per the book.
The interesting part of the experience was that in the linkage section it mentioned setting the carbs at a certain place and then go over to the specifications and do a carb low speed jet adjustment.
That's when I found that I am supposed to have #1 at 1/2 turn and the other 2 at 1 1/4 turn. Well, when I started my fiasco a week ago they were all 3 set to 1 1/2.
After I made the adjustment, with the idle set by the correct timing (5 degr before) the idle settled down and the engine ran (on muffs) really nice.
So, apparently some of the explosion problems I had were caused by too much fuel in the mix on #1 and apparently this fuel would collect in one of the other cylinders and periodically explode.
Soooooo how is it that #1 is adjusted so lean? Don't I need some fuel/oil in the cylinder to keep it lubricated?
Thanks,
Mark
Thanks,
Mark
