Kill it n grill it
- Joined
- Aug 4, 2010
- 15
Ok gentlemen, I have the outdrive re-installed, the lower unit back in, the gears are now working fine. Thank you to all that helped.
The last item I need help with is this: When I pull the throttle back it shifts into reverse immedietely. When I push the throttle forward, I have to push it down a bit to get it to go into forward. How do I adjust the cables in order to get this to tighten up a bit?
