1988 5.7 merc w/ alpha 1. Raw Water. 140 deg thermostat. New water impeller in outdrive over winter. New exhaust system and water pump last season.<br /><br />Idling on the muffs my engine overheats. When the engine is running, I get a steady strong flow from the exhaust relief ports. The exhaust water and manifolds never feel warm when the engine is overheating. Tested thermostat and it's fine. Overheat still occurs without thermostat.<br /><br />Can I rule out the water pump in the outdrive? If not, what could be wrong? Where might I look next?<br />thanks<br /><br />nat
