One Spark Plug looks lean
flyingd
I have a 1969 starchief V with the 4 cylinder 120 hp in it. Serial number on a plate, 2647628.
The number 3 cylinder spark plug looks like it is running lean. Number 1& 2 look fairly normal, 3 looks lean and 4 looks almost fairly normal.
What do you think will cause this.
Don s 2
Re: One Spark Plug looks lean
Do a compression test. Low compression will keep the cylinder from sucking in the fuel.
Ayuh,.... Water will clean sparkplugs, brand new clean, but you say it looks lean,....
flyingd
The electrode that you bend for the gap looked white. It was the only one looking like that. They are brand new ones too.
Just curious, does one barrel of the carb feed two cylinders and the other barrel feed the other two??
Don S
Nope, do the compression test. That will tell the story.
flyingd
I will have to do the compression test. Thanks for the help.
One other thought; are the valves hydraulic or solid?
Ayuh,.... Hydraulic,...
flyingd
forgot to ask.........what should the compression be, besides even that is
Ayuh,.... Generally speakin',...
100/ 110 is a rebuildable core motor....
120 to 130 is a Tired motor,....
Over that, is a Healthy motor,....
flyingd
Thanks, that is very helpful.
I will be doing the compression test next week and will let you know what happens
flyingd
Ok I did the compression test after letting the engine warm up in the sun. I wiil give 2 numbers, 1st will be normal comp test and the 2nd will be with oil squirted in the cylinder.
1- 115, 130.
2- 112, 125.
3- 105, 125.
4- 115, 125.
Those are the numbers. Tell me what you think.
Thanks.
1- 115, 130.
2- 112, 125.
3- 105, 125.
4- 115, 125.
Thanks.
Ayuh,.... She's Tired,.... A rebuildable Core motor...
flyingd
I was afraid of that.
Where would I find a long block................or the parts to do the overhaul myself.
