Re: online manuals
Hey thanks for the help donwon. Jack, I am actually looking for preventative maintenence for a boat that has been sitting for about two years. So far, I have done a lot of engine stuff (oil, filter, plugs, break free in cylinders, turns over easily now, cleaned out 55gal of old fuel, ect) but now I am wondering about the drive before I fire it up. I took the water pump out and as expected it was toast. The thing that really scares me is a couple of the rubber fins are now M.I.A., and we both know that they went somewhere. I am also concerned about a filter or screen that the parts diagram shows in between the upper and lower. Is this part of the water system? I removed the upper cover plate and saw no oil on what would be (to me) the ring and pinion gear. I notice that there is a check/fill plug and what looks like a dip stick from the top. Basically anything that you think might be wrong I would like to take a look at even if it means complete disasembly. I repair manual transmissions often so with the book I am not scared to do this unless there are components I am not aware of. Don't hold anything back! Thanks Kep
