Hi,
I had a 1996 40 hp mercury, 2 stroke, 4 cylinder, which is hard to start, I found when the engine is in idle, I disconnect the cylinder 3 & 4, theres no change, I bought 4 new plugs, same as before, and when I took off the all plugs, 3 & 4 are wet, looks like no firing, however, when I test the 3 & 4 I can see weak spark,
Any suggestion about the issue?
Thanks.
peter
Thanks.
peter
