only firing on two cylinders
trbass
I have got a 50 hp merc , only firing on two cylinders.... and suggestions.. motor has not run in a while ? thanks TR
Laddies
Banned
Re: only firing on two cylinders
It would sure help to have a year or serial number but I will assume it's a ADI engine so depending on which 2 aren't firing, it's 1&2 or 3&4 it's the stator but if it's 1&3 or 2&4 it's the trigger more info can narrow it down.
trbass
thanks for the quick response , freind of mines engine , I will know more
saturday when he brings it over .. thanks again trbass
Laotzu
I have a 50 3 cyl. It had sat for 4 years before I bought it and after I ran it for a while it also ran on 2 cyl. like yours. The problem was varnish flakes/gunk in the top carb which cut off the flow of fuel to the top cyl. Pulling the carbs and cleaning was fairly easy.
Jerry
