Re: only one dead coil
Not familiar with your rig. IF you have an epoxy sealed unit with multiple outputs your sealed unit could contain separate solid state switching devices for each cylinder.<br /><br />With that said, it sounds like one is defective. Not uncommon in the electronics industry to have malfunctions. Most are infantile so they do things like "burn in" components and systems to weed out premature failures. On outboard motors, I doubt this is the case.....too expensive.<br /><br />On a coil and points setup, one switch (points) fires every cylinder so if the points fail the whole engine is dead.<br /><br />Mark
