iloveketchup
- Joined
- Dec 4, 2010
- 54
After repowering my boat with a new motor I finally took it out on the water today. Fail! When going into forward all i could get is reverse.
I disconnected the shift cables in the water and tried to manually shift through gears but again no luck.
I'm worried that a week before i was out doing final cable adjustment checks without the steering connected and when rev'ing the engine it drifted to the side and "tinked" a cynder block. (assistant said area clear). The prop appears correct (right hand).
Shift cables are brand spanking new.
Potential causes/fixes?
- did they make a reverse gearcase? (replace lower unit or potentially prop)
- sheared mechanical in lower unit (replace/rebuild lower unit)
I have a later model 1985 looper. Is the lower unit interchangable with a 1978 crossflow? I'm noticing the shift rod is a little different on drawings. Will that make it not work?
1978 lower (pic from shop.johnson site)
1985 lower
Thanks in advance
1985 lower
Thanks in advance
