fishhead24
- Joined
- Apr 4, 2004
- 19
Hi, I have a 1985 Mercury 50 HP 4 Cyl. It ran great last summer, then whe I first tried it this year, it had no power! I figured carb problem, so when I was about to take carbs off I noticed the stator and trigger wires had(Green Death) insulation brittle and wire green and disentegrated! I replaced stator and trigger with CDI parts. Now it only has spark at the top cylinder! The new stator and trigger wire colors are identical to the ones I replaced and are wired up the same. I switched the coil signal wire and it sparks on that coil, so I know its not the coils. Power pack? Or bad trigger? Any tricks to test would be appreciated. The s/n is A100677. Thanks
