Beefer
- Joined
- Aug 4, 2008
- 1,737
1959 Johnson 10hp QD-20
I clean/rebuilt the carb last night, and now it won't run at any throttle setting except WOT. I started with the hi speed needle set about 2 turns out from lightly seated, but it ran tons better at <1/4 turn out from seated. I don't think that's good. Low speed I can't even come close to setting, because if I move the throttle off full, she cuts out pretty quick (less then 5 secs). I did notice that it seems the pitch changes in high when I'm turning the low speed needle in full. Is this an indication of worn out needle valves?
Over the weekend, I had her out and was running great at anything other then idle (which is why I decided to clean/rebuild). On Wednesday, I added a full can of SeaFoam to about 4 gals of fresh (<1 month old gas). On Wednesday after the SeaFoam, she topped out at about 6-8mph, and wouldn't getup on plane. I just added 4 gals more gas before starting it for the first time today, and had about 1.5 gals of the SeaFoam mix still in it. Is the SeaFoam my issue (which would be a non-issue), or is it something else?
One other thing, I can not get the low speed needle valve to stay in one place no matter how much I tighten the retaining nut, unless it's seated.
As always, thank you in advance.
