allinmygarage
- Joined
- Apr 19, 2009
- 76
1988 Evinrude 28 HP on a pontoon.
So I went to replace my first impeller on the pontoon. I unbolted the lower unit and started to lightly pound on it to get it to drop down. After about 10 min of hammering on a cloth (protecting case) it had only dropped down about 1/8 - 1/4 of an inch. That is when I called the local marine and asked if there was something I was missing. Sure enough I needed to remove a small plate on the side and then loosen 2 bolts. The lower bolt being a set screw. After they were loosened it came right out no problem. I replaced the impeller no problem and bolted everything back up. It runs and flows water better then ever. However now it will only shift into reverse or neutral. I have rechecked the shift rod and made sure it is in the correct spot and aligned with the set screw. I can watch as my wife shifts the rod go up and down as it should. However it now comes short of going into forward. I have adjusted the shift cable and now it will come really close to the point that I can reach down on the engine and pull a little and get it into forward. It is currently adjusted all the way and will not go into forward.
So what could I have damaged or bent and where should I begin. Sorry for the long post and any help is appreciated.
-Matt
-Matt
