JSGOLD
- Joined
- Sep 22, 2009
- 609
I was removing the carbs this morning when the brass outlet from the top carb popped out while I was trying to remove the fuel line. I have two carbs and the top one has the brass fitting at the bottom, feeding the lower one. Looks like the hose gets hard as a rock when cool......I assume this was pressure fitted in the carb but what should I do to make sure it seals properly???
Also, after seeing what this alcohol resistant hose has gotten so hard, would a good automotive hose do better?
