Here is another impeller thread. 1996 Force 120hp. Put the lower unit back on, in foward just like it came out. Slid back in fine. Tightened everything down. shifted into neutral okay. For some stupid reason I thought to try reverse. Was noticably tight but gave it just alittle more effort and "SNAP"! Well I took it all apart and the shift shaft is okay, but it appears to have sheared the dogs or whatever the lower unit shift shaft connects to way down low. Can I pull the prop off and slide all the guts out of the lower unit w/out making more problems. I guess the damage is done and I don't see any other solution. The shift shaft turns freely in the lower unit, and I slid it out and no damage to the shift shaft. It is still in foward and is engaged properly but have no use for a boat that only has foward gear. New boat to me. I've gone out twice w/ the boat, no problems but wanted the piece of mind knowing it has a new impeller for the weekend. Now I might be staying home
