Operating at 4200ft..could I be running too RICH?
MattP51
J 150 2stk o/b 1990 v6 going through 6 gals in an hour operating at 1/2 to 3/4 throttle.......If this engine originally was calibrated for sea level, could I be overly rich?
The boat is only a 16' tri hull.
guywithboat
Re: Operating at 4200ft..could I be running too RICH?
It is possible with the thinner air. I would contact the manufacturer.
MattP51
Good idea. Anyone know if leaning the carbs is as easy as turning a screw or are we talking re jetting?
wilde1j
No question at all if your motor has sea level jets. No srcrews, just jet change. If your not sure about what to do either get an OEM shop manual, or have a dealer do the change.
h_lankford
Are your spark plugs telling you that your are rich? My 16 ft with 60 hp at 3/4 throttle burns 4 ga/hr with just driver, so your 150 hp burning 6 ga/hr doesn't sound so bad. At 1/2 throttle you may be plowing and actually need to speed up for best economy.
Here is a purely mathematical way to look at it ( not proven by me on the lake) : Atmospheric pressure at sea level is 760 mmHg, at 4200 it is 656 or a reduction of 14%. So if you have sea level jets and running 14 % too rich, and then change to leaner jets, then you may theoretically save 6 ga/hr X 14% = 0.84 ga/hr. Your actual saving will likely be less than this as the 14 % doesn't apply to the whole 6 ga figure ( there is a certain minimum consumption no matter what).
Texasmark
Man, sorry I can't help you. I am a sea level guy.
Mark
Texasmark
Mr. Lankford. I don't know you, but I already like you. You deal in facts and facts are what make things happen. I try to answer the post inquiries with facts if I don't have true life event encounters (experiences) to supoport my jabbering.
Welcome aboard dude, er ah sir. 8)
Mark
MattP51
An average car can drive an hour and use only 2 gals.....why do these small boat engines use so much gas?
VADER8674
no transmision t aid with take off one gear thats go
h_lankford
Mark, thanks for the welcome.
MAttP51 why do boats get poor mileage? they are plowing through water, not rolling on smooth asphalt for one thing. ANd boats propellers are churning and wasting energy, not directly putting it to use without slippage. Kinda like a P51 in the air. You like Mustangs?
Had fun with my 60 hp this weekend. Only minor glitches ( at sea level)
Harvey
MattP51
I have a 68 fastback big block and a aviation nut
