Operating temp for a omc turbojet 115
Surgeevg22
Hi guys.
I just got home from the lake and I had a fealing the engine was running hot. The warning horn did not previously work so I bought a replacement. The engine did not seam any hotter then it previously has but it is so hot to the touch. I can hold my hand on it for a second at most. The alarm did not go off, and I know it works because if I ground either of the 2 wires the alarm goes off. My question is: should you be able to hold your and on the engine after running it at wot, or should it be as hot as I described.
Next time I go out I will get an ir thermometer but I'm curious as what is normal for this engine.
Water is circulating so I know it isn't lacking water.
Any input would be great.
Thank you
