I have a 75 HP Mercury with a WOT range of 5000 to 5500 rpm's. I had a 13X18P SS prop on this engine. It is on a 16 foot Skeeter Starfire 80. The boat weighs 825 pounds and the motor weighs 275 pounds. I was having serious problems with kick out on turns. I needed to constantly trim the motor up and down while driving in bayous. I decided to try a Solas Amita 4 blade aluminum prop (12.5X21P). The idea was it was better to test a $110 prop versus $400 on a stainless steel prop and not like the results.
Bottom line the new prop has completely changed the performance of my boat. No more kick out on turns and it now handles like a Porsche. The hole shot is a little slower than that of the SS prop, but I can live with it. Top end is a little slower, but again, something I can live with. The boat now rides on the very back of the hull while the boat is almost level when driving. The problem is that WOT is now 4900 rpm's and that is with the motor trim all the way up. Should I be worried about the fact that its not with in recommended WOT by 100rpm's or am I good? And if I decide to purchase a SS 4 blade should I stay with a 21P or should I go with a 19P?
