Ok you guys are probably sick of answering prop questions but after reading a hundred post I'm still not sure if if I have the right setup. I am very new to boating so I just want to make sure I have the right gear. I have a 86 Bayliner 19.5 ft. with a 350 V8 and a volvo 275 outdrive. I have no idea what the gear ratio is or where to find it. I took the boat out yesterday and felt the boat had plenty of power and accelaration. Unfortunately I was hesitant to push it to it's limit and also being on a lake that has 45mph speed limit. The boat prop is stamped with 14 19 R. By reading all the post here I assume I have a 14" diameter and 19" pitch. Yesterday I was able to get 5300 RPM without hitting WOT and I saw the RPM go higher a few times so probably means some slipping during accelaration. No problem at all going 45 with 4 adults and full tank of gas and I'm sure it will go much faster. I plan on doing some tubing and maybe some skiing this summer. I do not have any trim tabs but I tried the whale tail and didnt notice any difference as far as getting on plane faster on lower speed. So do I need to do anything with my prop size? Trim tabs would be nice too since I find myself looking over the windshield to get a better view until it planes out.
Clif
Clif
