juno pierrat
- Joined
- Dec 14, 2013
- 355
have had a over heat problem when idling for 2 to 4 min. when this happens I'll idle up to 1800 to 2000 and alarm stops in 20 to 30 seconds. so I've chased the problem, new water pump, thermostat, pressure relief valve. this last weekend went in muddy river and pee hole clogged at water passage cover, soooo took cover off, very clean inside, no scale or crud, i use salt-away every weekend , cleaned elbow for pee hole, and will reassemble soon.
next step would be to inspect water passages in head, but i really don't want to do that, presently compression is 145 per cylinder. and after seeing inside water passage cover i would think head passages would be clean too.
fuel pump rebuilt 2 summers ago.use ethanol gas with treatment, use 5 to 10 gallons every weekend weather permitting, 60 hours a year
could this be a lean idle condition, causing temp to rise slowly, i have always had to pump bulb at slow troll or long idles.
