Re: Opinions on my strategy, please....
Sounds like you're on the right course.<br /><br />I think you're making a little unnecessary work for yourself on the transom though. I've had good luck with I/Os by just using the 2 pieces of 3/4 plywood-- the green pressure treated stuff that won't rot in a few years.<br /><br />The weight that will bear on it is below the penetration where the drive unit comes through, and on your tow eyes if you pull something.<br /><br />I'd just put the plywood together with 1 heavy layer of mat/resin on the side that will contact the inside of the outside skin. Draw it up against the inside of the outter skin with plenty of clamps, and the bolts and such that will be on it anyway. That should fill in most of the voids between the skin & your new board. Or at least the voids around the contacting and stressed areas of it the voids in blank areas that don't really bear any weight or stress won't really matter**.<br /><br /><br />**<br />I worked on a 23' I/O once that was pushed by a 351 Ford, that only had wood around the sterndrive's penetration for a foot or so, but it went from top to bottom.<br />The sides of the transom coming away from it to the edge of the hull were cardboard--- yep, cardboard like they make cardboard boxes from. But since there wasn't any stress on the outboard centers of the transom, it worked fine and didn't weigh much.<br />**<br /><br /><br />Then fill the irregularities around the outside edges and under the board with thick mix of chopped up mat & resin so the stresses are transfered/disspersed to the hull as evenly as possible. <br /><br />.....<br /><br />If your eng. mount uses 2 big slabs of wood- 6 x 8, or whatever, they will have irregularities under them too. Try to save a inch or so of the edges from the fiberglass that held in the old ones. <br /><br />That way, you'll know where to set the new ones, and you can put a layer of waterproof filler like Dynatron's 'Dynaglass' or Marson's 'Kittyhair' to fill the gaps between the hull & the bottom of the mount itself, and the weight/load will be transfered to the hull evenly there too. <br /><br />Also, stuff the mix in the gap between the eng. mount ends and the transom board. This does the job of spreading the stress from the transm to the hull like those triangle shaped 'knees' you see at the bottom of outboard boat's transom tying the hull to the transom. <br /><br />Mix the stuff up with a minimal amount of hardener, smear it on the bottom (and the ends) of where the eng. mounts will lay -- like a thick layer of peanut butter.<br /><br />Place the mounts in the hull, and ease the engine down onto them so they settle in where they're supposed to be before the stuff sets up. It will be a permant fix that is just as strong as the factory did when they built it. <br /><br /><br />There's at least a dozen ways to attack your project in this reguard, but this will work, and is fairly quick to do.<br /><br /><br />Ed.
