kdiddle
- Joined
- Mar 22, 2018
- 147
Morning, all. My original starter on my 1964 Speeditwin finally bit the dust. I took it apart to see what kind of shape it was in, and apparently my brushes completely disintegrated into oblivion. Not able to find a local shop that could rebuild it, I went online and cross referenced my starter to an aftermarket one.
After receiving it, it was apparent that its a full inch shorter than the original, so I am unable to mount the bottom plate to the starter. The top bolts lined up and are holding it fine so far - but I'd love to hear from you guys on whether or not the two through bolts into the top plate are enough to hold it, or should I attempt some sort of bracket fabrication / washer stacking nonsense to make sure the bottom is properly supported?
BTW - I called and checked with the group that I got the starter from and they confirmed that I got the right starter, but they have no idea why its shorter than the original and were no help in my finding an answer to my question.
