Reggie08
- Joined
- Mar 31, 2008
- 243
I'm hoping I can get some opinions on the need for re-jetting carbs for simple fact, I'm trying to determine if I have a need for it.
I have an 85 'Rude 90hp that I completely rebuilt the powerhead on. In the process I replaced the block because the old one was bored .030 over already and I had some pretty substantial scoring on the cylinder walls. The current block is bored .030 on three cylinders and .040 on the 4th (#3 cylinder to be exact). A local mechanic here told me I would probably need to re-jet because as he put it, "it'll idle like a 3 legged dog". His reason being, the cylinders were larger requiring more fuel/oil. Since re-accomplishing my link-n-sync, the motor idles very well/smooth in my opinion (better than the last 2 outboards I owned). So re-jetting for that purpose I think, is unnecessary. Another mechanic in the same shop suggested I bore the current jets out "4 thousandth's" which I'm uncomfortable with doing.
However, I'm concerned with the possibility of a lack of lubrication issue arising. Will the larger cylinders require me to have to re-jet up a size or two? My current jet size is 56c which is the standard size per the OEM manual/parts diagram.
I'm still in the break-in period and as such, I'm using a 25:1 mix (bypassed the VRO system) so lubrication right now shouldn't be an issue. But once the break-in period is over, I'll go back to a 50:1 mix. Should I considered re-jetting? Is there ever a time when re-jetting is necessary?
