Opinions Wanted
Marpet
1995 Rinker 180 w/ 3ltr merc/Alpha1
The access holes under the bow cushions are small. I have owned and seen the new Bayliner 175's, which are about the same size, have an elongated access port. Can I/ should I/ would you take a skill saw and enlarge the holes to make them more user friendly? I can't see how it would be structural or cause the cushion to sag (not going to take THAT much out). Plus, the cushion is on a plywood base.
Thoughts?
Gord
a70eliminator
Re: Opinions Wanted
Sounds like something I would do, just so the cushion bases have enough support is all that matters.
onedaatmc
Re: Opinions Wanted
I'd sawzall 'em up , you can always make hinged lids for them , if the seats don't quite fit afterwards
slasmith1
Re: Opinions Wanted
just make sure to properly seal any cut surfaces to prevent water intrusion into the glass.
Marpet
Re: Opinions Wanted
Good point Slasmith, I hadn't thought of that.
That's my job for tomorrow. After golf.:D
Gord
