Optimax Alarm Voltage
DuckHunterJon
I have an odd question. I just bought a boat with 200 Optimax. Up under the helm there is a small piezo alarm that beeps on Key on, as well as under other faulted conditions.
My issue - I told you this was going to be odd - my dog is deathly afraid of loud beeps. I think it goes back to a faulty smoke detector years ago when she was home alone. She is so frightened she almost convulses at certain sounds.
So, I want to look into options. Does anyone know off hand what the voltage on the buzzer is? One option I thougth of is to do away with the alarm and put in an LED in the dash to serve the function. Another option is to change it to a piezo buzzer that has a lower tone. Finally, if anyone knows if the key on signal can be over rode. I really like the idea of the problem conditions sounding off, just dont want Bailey to freak out ever time I turn the key on.
Any ideas would be welcome. Thanks.
J Hartman
Re: Optimax Alarm Voltage
I would have to assume it would be a 12v buzzer. I would keep the sound, Because it's the best warning you'll have vs. an led light. as far as the dog goes, i'm personally unaware of a different style of buzzer you could use as an alarm, maybe someone could chime in on that... check out automotive store maybe?
herb boughn
One thing for sure....you have to resolve alarm noise problem as you'll hear it frequently as long as you own an Optimax. They are problematic and 95% of Mercury mechanic's are clueless on how to work on them. I know a guy who had all the fancy certificates from MERC who replaced the WATER PUMP to correct what turned out to be a defective IGNITION COIL. Now two years later he is the lead mechanic at a BASS PRO outlet. :eek::p
