iammarcuse
- Joined
- Oct 15, 2007
- 131
2004 Optimax 225 on a 21' Ranger. The motor will cut out instantly while underway. No sputtering or loss of rpm first. It literally just dies completely like you turned off the key or hit the kill switch. Sometimes 10 times a day, sometimes not at all. The smartgauge reads "Engine Data Bus". The diagnostic computer shows no faults. When you go to turn the key again sometimes it will start right up, other times nothing for a minute or 2. Sometimes if you hit the trim switch it will then start up. Either way it always starts up again. The gauges are still lit up so I know the key power is still on.
It has been to two different dealers 5 or 6 times. They replaced the entire computer for $5000 and nothing changed. They have done new lift pumps, fuels lines and filters and screwed around endlessly at $120/hour. They say that there is nothing wrong with it, but they are not the ones driving it in the middle of the lake when it quits. Super frustrating.
Anyone have any experience with this problem? Any help will be appreciated.
