I have a pair of 2001 150 Optis that someone removed the hose that goes from the poppet valve to the top of the block and plugged them off. Any idea what the reason is?
I had some cooling problems with the port motor and one of the things I did was replace the hose. Now it doesn't overheat anymore but at idle has 1.5 psi and the Smartcraft reads 170 and the analog reads 120 degrees. The starboard reads 3psi 105 on the Smartcraft and 110 on the analog.
If I plug the hose off on my port engine will I get better cooling at idle?
All cooling parts are new.
Ser # OT274141 and OT274461
Thanks
Thanks
