Optimax Pro XS 150 - 2013 would not fire
phmatt
New pontoon boat was delivered with 550 MCA battery. Motor calls for 1000 MCA battery.
Used boat all last summer, it cranked fine boat always seemed to barely turn over.
I had an older 1000 MCA that I charged up and put in this weekend. Turned the starter
over no problem, sounded very strong. Motor would not fire, could not smell gas , just
a big puzzle. Googled around yesterday read that a battery could be strong enough
to turn the starter but if the amperage dropped the motor would detect that and not
fire the fuel nor air injectors. Sounded goofy to me, but I bought a new 1000 MCA
yesterday, put it in, motor fired right up.
Thanks to whom ever did the original post.
PS. Talked with several mechanics non of which suggested that at all.
Fun Times
Re: Optimax Pro XS 150 - 2013 would not fire
Yes it's pretty important to have the correct size battery with the newer engines models.
Since you have a new 2013 boat/engine, did you buy the boat new at a dealer? If so, it may be a good idea to call the dealer too let them know to be careful as it sounds like they are installing incorrect sized batteries.
