Optimax Speedo display 'locks up'
cracker56
Dealer says live with it. This is not right. When starting both gauges start to work "both load Mercury logo" but Sometimes the smartcraft speedo just locks or goes blank. Only the speedo, tach works every time! I found that if I either pull the plug on back og the gauge or turn off engine and battery then turn on again it usually works. It also holds the display after ignition key is turned off. Out of warrenty. Could it be a miswired ignition switch? Any ideas?
moderator1
Re: Optimax Speedo display 'locks up'
Moving to Outboards. I think you may have a better response there. It was a tough call.
dilligafda
Tell your dealer to suck an egg and contact another dealer. We've seen this before, replaced the gauge and the condition went away. Coincedence? NOT!!!<br /><br />Have your (new) dealer contact Merc to see if they will help with replacement. Good luck! ;)
