2006 2 stroke 115 hp optimax. For the past few months that I have had an issue starting. It will start eventually but typically when the key is turned I hear a beep and one short noise from the engine/starter when I turn the key to start. The starter does not contunue turning. The engine is silent and does not turn over. I will turn the ignition off, ensure in neutral, turn key again. I need to do this between 3 and 10 times and then it starts. Engine runs fine after starting. Any ideas?
The only thing I found online was..I suggest of having burnt spot, when the contact washer rotates to the burnt position it fails connection and the starter will not crank. Maybe?? Sounds plausible.
