Re: optimax starting problem
SORRY MY TIPS DID NOT HELP! i will try listing some other things that may help. #1 good quality fuel??? try fresh gas from a 3 or 6 gal. portable tank, and flush the system at fuel rail pressure fitting as you cycle the key switch and pump the primer ball, keeping the vapor seperator full. spin-off the fuel filter and dump in glass jar to chk. quality. #2 are you loosing spark??? use a timing light to monitor ignition. #3 can you keep the motor running if you advance the throtle? monitor air rail pressure #4 the spark plugs must be one of two: NGK-IZFR5G= new recomendation
NGK-PZFR5F-11= old plug
did the motor run o.k till you put in new spark plugs? (sorry to ask, but this has happend in the past) #5 chk. for fuel in the air rail. (possible blown tracker valve diaphram) #6 any codes? (need merc. software or ddt)#7 try an other key switch and wire harnes assembly. (there could be continuity between the blk.-yellow wire and any other wire in the harness or the motor is not geting clean voltage from the "key-on" circit on the purple wire. also chk. the fuses. sorry if you already did the basics i listed. good luck!
