robaloroger
- Joined
- Feb 16, 2010
- 123
I have a 2000 optimax 225 with 120 degree t stats 850279-2. My motor was over heating so I removed the t stats and tested them. The book said they should start to open between 188-122 if not discard them. They were starting to open at 135 degrees so i ordered 2 new ones. Got them and tested them and they start to open at 135 also. I tested them with fast rising heat and slow rising heat and both the same. So either the old t stats are good or the new ones are bad. either way I wasted $75. Are these t stats bad? Anyone test any t stats that open within the range they say they should?
