Re: Optimum compression readings for '86 140 Evinrude?
On a 2-stroke, static compression relies heavily on the port timing. Since port timing is a function of engine design and performance, you cannot compare one hp engine to another. For example, later big V-6 J/E engines are well known to normally produce around 90 psi static compression while my brother's 4hp looper produces around 140psi.<br />So you really cannot compare across the board, or even between a few years as port height is a common 'tweak'. Static compression doesn't have a strong relation to performance on 2-stroke engines.<br /><br />Then there's all the other variables. Gauges and testing practices seldom agree. If you're at a high altitude even, you can expect lower readings. If the engine is warmed up you could get higher or sometimes lower readings. Battery state will even affect it.
