Ratrace Remedy
- Joined
- Jun 3, 2007
- 5
Should the orange wire at the alternator be hot?
Trying to diagnose a no-charge condition on my '84 Formula 350/260. Got the alt rebuilt (Mando) and still not charging (per the dash gauge and a volt meter at the battery) The smaller sense and excite wires I confirmed are connected correctly and the ground is good. With the engine off and the orange wire disconnected from the alt, I get no voltage at the wire. Per the wiring diagram, it looks like it heads to the starter, and there's a square fuse between the wire and the starter solenoid. I can see it, but can't get to it due to how low the motor sits in my boat, and the tight distance between the floor and the exhaust manifold. Should I have a constant 12v comng from the starter to the alt? If so, I suspect the fuse, but want to make sure before I go through the hassle of removing the manifold to change the fuse (I'll try a couple of long extensions first
thanks
thanks
