cjflanagan
- Joined
- Oct 1, 2003
- 168
If I'm out 180 - can't I just switch the wires around on the distributor 180 and be right on?
Yep, that's the easiest way... keeps things "by the book" too.Originally posted by Haut Medoc:<br /> Why not turn the dist. around so you can set the timing properly?.....JK
Justr gotta be careful which way you turn it; could end up being out by 360!Originally posted by Haut Medoc:<br /> Why not turn the dist. around so you can set the timing properly?.....JK
You aint right man!Originally posted by Mischief Managed:<br />Justr gotta be careful which way you turn it; could end up being out by 360!Originally posted by Haut Medoc:<br /> Why not turn the dist. around so you can set the timing properly?.....JK![]()
