finally had time to get into my engine swap yesterday... (replacing 4.3 with a fresh built 383) 4.3 is out, 383 is done with only a little "dressing" to do with some of the things needed from the v-6. after I got it out, test drilled flotation boxes, etc... figured if I'm going to completely redo the engine compartment today before putting the engine back in, better check.. thank God no water or wet drillings anywhere, so I get to glass in the new engine mounts, fill all the fastener holes and shoot paint this morning / early afternoon. touch up paint a couple little things on engine parts and put the new engine in.
finished final polishing and buffing of new imco powerflows, filled lettering with red metallic to match engine colors and then clear coated with por15 glisten, they look awesome!
Where there are old fasteners or other holes that ave been drilled anywhere in the engine compartment, I'm going to drill out larger and fill with peanut butter, then spray the entire thing. Still not sure exactly what paint going to use on the engine compartment. have several options on the shelf. am going to stick with the original black, and think I want more gloss. I'm very tempted to lay a coat of thinned epoxy first and then once cured, cover with two part polyurethane, maybe auto paint like nason fullthane (have had very good luck with that on several projects now and it seems to hold up great even on engine paint...). I've read a lot on here about different options for coating the bilge... I'm planning to do the sides and front (not very visible) with ruberized undercoating for a little sound dampening and am very tempted to top coat the whole thing in undercoating - it is tough stuff and what my engine builder had me coat the bottom 3/4 of the oil pan with to help with corrosion. Any thoughts here would be apopreciated, but I'm sure any of the above will work out fine and can touch things up as needed once the engine is in... have a good amount of room.
I'm not realy liking the degree of movement in the rubber engine mounts, but they lok like they're in good shape for what they are and will go with em for the time being. I'm a little tempted to chain engine down and use turnbuckles to tighten / adjust for a little added rigidity, although this would most likely transmit a lot more vibration noise through the hull...
Was also nice that when I pulled the outdrive, there was no water or any signs of it anywhere... don't think I would have gotten the bellows changed succesfully without the input and information from people on here... that and some other things that I've done since.
Wth a little luck and assuming I get the carb jetting right on the first try, I'm hoping to be ready to test run / break in cam on the new engine tonight, and have the boat in the water for shakedown onf the new set-up by Sat...
Assuming all goes well, can put the 4.3 up for sale next week (fogged it took movies of running etc... yesterday before changine oil and pulling it..) and get the interior done in plenty bof time to spend the summer on the water instead of in the shop...
so on outdrive... not sure which to try first... 1.84 gear ratio with 28 or 30 pitch prop or 1.5 gear ratio with 21 or 23... (I have both upper outdrives and either already own or have place to borrow the props to try) the 1.84 is installed and may get the nod for this weekend just due to sheer "laziness"
headed out to get a couple plugs for the water jacket openings on the heads, and a few other misc. items and then back to work... beautiful day for it. Have a great day and thanks (to those who have been helpful) for all the information / perspective...
