Re: Outboard bogs under heavy load
Yes I have read a little about losing a cylinder and it sounds like that could be the problem. When the problem occurs, I put it in neutral and rev it up a little bit, then put it in gear and usually it will get up and go again. Initially I thought the plugs were fouling up maybe due to too much oil, but i'm worried it might be more serious. I use 93 octane without ethanol and with yamalube oil. What are the reasons for losing a cylinder? Does this indicate a serious problem with the engine? Really just wanting to know if I need to take it to a mechanic to diagnose and fix the probelm or if it is something simple that I could do. When I noticed the probelm, I changed the plugs which didn't do anything. I also switched to using 93 octane instead of 89, which seemed to help because it happens less frequently, but it did not resolve the problem.
