I have a 65 HP Merc, 3 cyl, 2 cycle, outboard motor. 1970's I think. It runs as smooth as a sewing machine. It has three batteries, one for motor, two for accessories and 24 volt trolling motor. The only switch I have for monitoring the batteries is three way switch. Off, Main, Aux1, Aux2. The voltmeter is installed on the panel and when charging with the battery charger, it reads 14volts. This is normal for the charger. I was running on the lake and decided to test the main battery and noticed that the volmeter was in the red at 16 volts or close to it.
Obviously the battery is being overcharged by the motor. I don't know much about the charging system on the motor. Is there a regulator? Can it be adjusted? does it use a starter/generator? or another type charging system? I have ordered a manual, but would like some info. thanks..Whirlypig
