Outboard Crankshaft Repair
Jomusky
Does anyone know of any company which repairs crankshafts? I have a 81' 175 Merq 2.0l and my fuel pump went bad causing the motor to run lean. Two of the rod journals have spawling on them from the lack of lube. All the local shops say that welding or chroming doesn't work. The only place I've found so far is OCC in Seattle and they want $658. <br /><br />How about a good used crank?
Re: Outboard Crankshaft Repair
Definately go used dude. As an auto mechanic I come across this problem often and believe me...It aint cheap to chrome a crank, But it can be done..( depending on the amount of wear it took..)<br /> Good luck....Check E-Bay
Dhadley
Contact Jack at Superior Marine at 800-338-9281. Ask him about used and rebuilt. He's pretty much on top of things in that area.<br /><br />Good luck!
kenthrussell
hi was it fuel injected? ...check and see if a 1987 200hp merc crank will work as i have a good one...that is outboard your talking about i presume.
Rex
CHROMING YOU GOT TO HAVE AT LEST .030 BUT<br />I WOULD NOT DO THIS IT'S GOOD FOR PRESFIT <br />BEARING.<br />REX
Jomusky
Thanks for all the help. I just found a used crank for $310. That fits the budget a little better. The internet is so powerfull, I was able to get help from all of you, plus find and e-mail about 10 deferent used parts companies.
Jomusky
Kenth,<br />I believe the 87' 200Hp would be a 2.4L and my 175 is a 2.0L. Does anyone else know if this is correct? Or am I mistaken?
kenthrussell
hi well everything is the same ...block pistons ect. where you get the other 25 horse is through porting and carbs....looked them up on the merc parts express ..excellant web site all you need is serial numbers and they will give you parts numbers and prices
Jomusky
That's great Kenth, how much do you need for it? Is there anything wrong with it what so ever? Seal surfaces? Thanks again for all the help!
