dustindaugherty26
- Joined
- Aug 2, 2022
- 3
Have a Johnson 50hp from early 80s. I took it out the other day. Pumped primer ball. Engine fired right up. Ran for about 2 or 3 minutes at full throttle traveling across lake then seemed to drop to half power for about thirty seconds, then quarter power for thirty seconds then died. Refired a few times and would die as soon as I attempted to put it in gear. Then had trouble starting at all as if it were flooded. If I let set for a few minutes would fire up for a few seconds and die again.
Some things I noticed: At home I could fire it up and let it sit at idle. Would run for about a minute and then slowly lose power and die over the course of 30 seconds or so.
Primer bulb never got “hard”. Always felt somewhat soft. I could hear fuel spraying into carbs while pumping ball and not running. Tried pumping while running, no better.
No leaks in engine that I could detect. Possible small leak at hose to tank hookup point when pumping ball.
If I pump ball with hose disconnected from engine but not tank it gets solid as a rock.
Could this small leak be enough to cut engine out every time so quickly?
