Maxum21
- Joined
- Mar 8, 2005
- 219
I have a new to me 18' larson with a 115 Johnson 20" shaft. I had a 13.25 x 19 prop on it but did not run right with it. Seemed to possibly "cavitate", ecspecially while making turns. Another member on here told me i was over pitched and recommended trying a 15 or 17 pitch which i'm going to do. But before i start buying props i wanted to make sure my motor height is correct. This motor isnt original with the boat, so wanted to get opinions on whether the shaft length is correct for this hull. The transom from top to bottom measures 20.5", however the transom tapers foward a few inches and then drops down another approx 2.5" which is the hull bottom. Now what i'm unsure about is should the anti-cav plate be level with the bottom of the transom or level with the lowest part of the hull? The motor is currently in its lowest mounting position and the cavitation plate is level with transom bottom, not hull bottom. I attatched some pics to help explain what i'm saying.
thanks in advance
thanks in advance
