TwoWatt
- Joined
- Nov 4, 2001
- 249
Hi.<br />I am about to attempt to install a 60 hp outboard on my boat & had a couple questions. <br />When I took the nonrunning 50hp off it was only held on by the upper clamps, but looks like they had drilled holes in the transom for the two lower bolts. I want to re-use these holes (assuming they line up, which they should, merc off merc back on) so that I can install an anti-theft nut/bolt. <br />I have purchased a tube of life caulk from a recommendation. But how should I do it?<br />I know I should make sure the lower holes match, drill out the old sealant,etc. <br />Someone told me to fill the hole with sealant & the push the lower bolts through, smear it on the inside & outside,etc. But how do I get the bolt through without getting sealant all over it? The bolt with the antitheft lock has to be clean so I can apply thread lock.<br />Any tips on how to do this properly?<br /><br /><br />(also, when installing the throttle controls, the first cable to move is the throttle, yes? I'm checking my manual now)
