outboard leg removal
johnjo
im trying to remove the leg of an evenrurde 15 Ive removed the gearbox , flywheel, starter motor, all the bolts on the side of the leg and mount bolts of the engine and it will not drop down.
There is a fork that goes into the leg but this will not come out
Do i have to remove the complete power head or what
What i really need is to remove the the bracket that attaches to the engine to get at the swivel tube
kenmyfam
Re: outboard leg removal
Do you have a manual ???
What year is the motor ??
Post your model number on the transom bracket for more accurate help.
Welcome to iboats.
johnjo
See if this helps:
Lower Unit
Thanks a million for that
but its the centre leg I want to remove
I have the bottom off and the bracket but I cant shift the leg or centre ie where the bracket connects to the leg and contains the swivel tube which is broken
boobie
If you don't have a manual you may want to look at shop.evinrude.com for a parts break down.
A model # would also help ??
raczekp1
under powerhead, at exhoust side are 2 bolts and piece of metal holding this "fork"
so first lift up powerhead and after takubg out powerhead you get acces to this 2 bolts
johnjo
Thanks for that,
But I removed 4 bolts ie two on each side of the leg going in at right angles into the leg
The fork is loose but will not budge
Are there two more bolts running some where in line with the leg which are hidden
I can only lift the power head half an inch away from casing
Maybe i should dismantle the powerhead a bit more
Have I lost you with all this ?
Cheers.
raczekp1
first take out powerhead, completly out from midsection,
if you yake out powerhead, inside midsection you notice 2 long bolts, take them out
lower part of midsection is atached to bracket system also by 2 bolts, this 2 one you notice just abowe lower unit and midsection joint
