199675hpforce
- Joined
- Feb 27, 2004
- 299
Been meesing with fuel pump today and went for lower unit as it was not pumping water at idle through pee hole only 3000rpm range so. Motor was cold to touch so im not worried about over heat. Ive only changed out impeller before no gaskets and such. How do pics look orange part is burnt and from behind bulged little. Is there master kit i should get to replace all gaskets, is the job easy. Another pic shows rubber part with plastic thingy on bottom for shaft. Did not know rubber part existed lol had it apart couple times it was stuck up there. Still not sure why it was not peeing, should I silicone exhaust side?
