Outboard Maintenance after each Saltwater use !
Joseignacio
After flushing my outboard with fresh water, I should open the engine cover and spray it with what ???
Thanks.
Chris1956
Re: Outboard Maintenance after each Saltwater use !
Saltwater is not hydracloric acid. A single use is not going to harm the motor. Flush the motor, and if you get some spray or drops on the block, hose it off. If you have extended saltwater use, don't forget to hit the grease fittings.
Joseignacio
I've been told to spray it with CRC each time, but there are about 5 different CRCs...... Which one is it ?
Thanks.
electricjohn
My outboard is 23 years old, with 1000 salt water hours, and I have never sprayed anything on my engine. Just flush after each use and grease the fitting yearly. A little seasoning (such as salt) is not your motors worst enemy.
