I recently noticed on my '84 17ft Thundercraft the lower motor mounting bolts were loose. It appears that when trailering the motor was allowed to hop and caused the bolts to pull into the fiberglass on the inside of the transom. It appears that the lower mounting bolts were put in the area where the floor meets the transom and there was a void between the fiberglass joint and transom wood. The holes in question are the second ones down on the lower bracket of a 90 mercury. Presently the transom wood is sound w/o rot or moisture.<br />Do I fill the holes and move up to the upper mounting holes on the lower bracket? What should the holes be filled with and what should I seal around the motor bracket with to prevent water infiltration? Also what would help in the future when towing to prevent a reoccurrence?
