Re: Outboard mounting height too High?? Older larson with new motor
There is no exact right height, it's a trial and error type thing. Level with the hull would be the absolute lowest point, but it should be higher, maybe an inch or so depending on several variables. So right now at 1/2 to 3/4 above is fine, but you might be able to go higher, you just need to try it and see it.
A 110 may be too large for your boat too.
It may just be that your hull design isn't all that stable, but you need to experiment to find out.
