Outboard needed!
THEPATRIOT
I have limited knowledge of these engines,and will need one for my 1964 16FT MFG Westfield.I want something from the mid "60's-early "70's.I'm looking for something reliable,any idea's???(EVERYTHING i have is OLD!)This is my first boat,i'm doing what's called a "driver restoration" clean and correct just not like "new".Here's a pic.(where i bought it)
daveswaves
Ensign
Re: Outboard needed!
What is the rating on that MFG, around 75HP? Mid 60s evinrude would look just right on that set up.
THEPATRIOT
Thanks.Are parts available for old Evinrudes's,Johnson's and Merc's?Any engines to avoid?
tx1961whaler
See if the boat still has a HP rating plate on it. It may not have one.
Parts availability depends on the particular motor. I'd personally stay away from a Johnson/Evinrude electric shift lower end. I like the 40 HP twins, but that's probably a bit underpowered for that boat.
speedcat2000
From what I have seen and heard, the old Johnsons are built like tanks and last forever, but if something major breaks, parts cost these days can be insane enough to prompt you to "use the engine as an anchor" or "throw it off the nearest bridge" instead of fixing it. I guess if you have the space you could buy a broken "parts motor" and try to get by that way. But for electrical parts you might end up having to bite the bullet anyways and replace that stator ($250-$300) or what have you out of pocket.
From my limited perspetive, there is awesome help here on these boards with Johnson/Evinrude motors. I see less help with Mecury here, although when you're buying parts and labor today it seems there are more places that sell and deal with Mecurys than Evinrude/Johnsons.
Talk to an outboard mechanic they'll tell you to stick with 1990s and newer motors. What is the fascination with the older motors... are you trying to do a period restoration or something? I'd definitely stick to a newer motor if I had the choice. :)
THEPATRIOT
I have to have period correct equipment,i'm silly like that.(with EVERYTHING i own)I found a mid "60's trailer today,so i just need the right engine.:)
