I recently purchased a 1994 30 ft Scarab Sport w/ twin 1994 Yamaha 225 hp saltwater series 76 degV outboards. The motors are mounted on a Stainless Marine transom bracket. The problem I am experiencing is that at intermediate speeds (30-40 mph) the motors tend to "hunt" about +/- 300 rpm. I think the cause is that the motors are slightly ventilating at this speed. I've tried all sorts of different trim angles with not much improvement. At higher speeds (>40 mph) the problem goes away and both motors hold rpms very well. I do not want to lower the motor mounting height as they already settle in pretty deep (nearly up to the motor cowling) when I back down off of plane. I'm considering going from a 3 to 4 blade prop to try to correct this problem. I currently have 23P props and my motors run at about 5,200 rpm WOT. I'm thinking about going to a 22P 4-blade prop of similar diameter. Any comments or suggestions would be appreciated, also, any feel for what the rpm drop would be by going from a 3 to 4 blade prop?
